Gluing Tail and stab?
I use 5 min epoxy for that. Make sure you cut the covering off where the stab touches the fuse. glue won't stick to the covering and your tail will come off. If you use slower epoxy, make sure you pin it well in the correct position so it doesn't move on you while the glue is setting. Probably wouldn't use CA. You want to make sure you get a good joint on the first bird.
