Hi there.
What you will need to do is to use the included shock spacers to either raise or lower the droop on your CT5. It is that simple.
Also, as an upgrade you could purchase the #G84290 threaded shocks. They are an excellent upgrade to your CT5 car. You can view the accessories at this website:
http://www.cenracing.com/accessory.html
Hope this helps you out.
