RE: How to stroke an engine?
Ah but like you said with no other changes. If you make the rod longer, whamo! it hits the head. Shorter it lowers the ratio and if you raise the head the same amount that you lengthened the rod no change. So it doesn't really mean much as far as compression ratio goes.
