RCU Forums - View Single Post - digital servo & battery
Old 03-22-2006 | 01:21 AM
cooperd
Default RE: digital servo & battery
ORIGINAL: spec36
thanks i came up with a 1450mah Nimh that has about the same weight as the 600 . and fixed it were i can change out easy just to make sure i also put a volt watch . will the volt watch drain the power ?
You are on the right track. I have a 2500 ma 4.8 pack (AA) size by JR. I replaced a 500 MA pack with it and I fly two or three outings and the pack is still way up. I only use standard servos, but the point is the new higher ma packs are the only way to go...not near as much fooling around recharging or wondering if you have enough for one more flight.
