RCU Forums - View Single Post - How to stroke an engine?
Old 03-22-2006 | 02:03 AM
DarZeelon's Avatar
DarZeelon
Default RE: How to stroke an engine?
Brian,
In full size engines, stroking is performed by grinding the crank-pins off-center (further out from the crankshaft C/L)and using smaller i/d rod big-end bearings.
If the crank-pin is ground 1 mm smaller, tangentially with its outer perimeter, the stroke would increase by 1 mm, since the center-to-center distance (crank-pin to crankshaft) would increase by 0.5 mm.
...But the crank-pin would also be weakened considerably...
