RCU Forums - View Single Post - Reverse Elevons
Old 03-22-2006 | 05:50 AM
gadlen
Default RE: Reverse Elevons
>servo leads plugged in the wrong channels on your receiver
But they can only be plugged into either Channel 1 and Channel 2 or Channel 2 and Channel 1. If I reverse them, that doesn't fix my problem. That would do just as much good as switching the forward/reverse (actually, I looked at them again, they're "normal" and "reverse" ) switch on the transmitter. If I had ailerons and elevators, your suggestion would fix my problem.
>I do not understand what you mean when you say you cannot get forward reverse setting to line up.
Ah, sorry. The only settings on the Laser 4 are little switches that read "Nor" and "Rev"... for normal and reverse configuration of each channel.
Lee
