RE: Blue Angel Wing is Born
Raineday,
That is exactly right. Parallax correction makes the wire exit the trailing edge at the same time. If this doesn't happen, the wing will have a really unusual airfoil shape.... Cutting a wing manually, you mark off the templates in "stations" and call out the numbers as you pull the wire thru the foam... the AMAP does this automatically... should have my picture ability by this afternoon, so will post tonight.
Dan
Carolina Custom Aircraft
