Well I have finally came to the conclusion that when using two elevator servos unless you can get them mounted in the exact same spot on opposite sides of the fuselage you cannot get the two halves to move equally by just reversing one servo. I just finished the Funtana 90 and use a servo reverser and the two halves are off by 3 degrees at full deflection. I guess I am going to have to break down and by a matchbox as much as I hate to.
Has anyone else had this problem and what did you do to fix it?
