RE: Official HPI MT2 Thread
Okay the short answer is the shocks are Newera ACC801 on the front and SCT801 on the rear.
I'll try to copy/paste the parts list i've been making but this list is about two years old so its massive. I have fears about what the formatting will do to it when I paste It up. Sorry if it makes the thread messy! It may be usefull for some though. I know I found the list Frost made earlier in this thread very usefull.
NOTE: Do Your Own Research!!!. >>Best bit of advice my room mate at collage gave me<<. PLEASE DONT BLINDLY BUY PARTS FROM THIS LIST EXPECTING THEM TO BE RIGHT FOR YOU.
I'd hate to be responsible for a dissapointing purchase! If in doubt, ask!
-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.Ultim8 MT2.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-
FEATURES...
Twin-Plate Chassie
Dule Brakes (not yet)
Head Lights (not yet)
Tail Lights (not yet)
Brake Lights (not yet)
Cold Air Intake (not yet)
Roll Cage
Wheelie Bar ??? << do you want it???
Water "Proof" (resistant)
Bullet "Proof" (susceptible)
PARTS LIST...
---CHASSIE---------------------------------------------------------------------------------
Wheels: >Ally Beadlock Wheels for 2.2 Tires - RC4WD: 4x4-BL05
Chassie: >2.5mm Super Chassie - HPI: 73948
>Graphite Upper Deck - HPI: 73100
>Aluminium Roll Cage - RC Solutions: 089
>Steel Screw Set - Ebay.JE Spares.
Gear Housing:>Aluminium Gear Box Front Purple - GMP: NMT2012
>Aluminium Gear Box Rear Purple - GMP: NMT2012
>Ally Centre Gearbox Silver - GMP: NMT2038S
Steering: >Aluminium Wheel Hexs Purple - GMP: NMT2010
>Ally Steering Assembly Purple - GMP: NMT2048P
>Aluminium Nuckles Rear Purple - New Era: HMT404V2
>Aluminium Front Hubs Silver - New Era: HMT403S
>Aluminium Nuckles Front Purple - Fastrax: FTHP95
Susspension:>Monster Duty Aluminium Shocks 120mm (rear) - New Era: SCT801
>Monster Duty Aluminium Shocks 108mm (front) - New Era: ACC801
>Graphite Rear Shock Tower - HPI: 73097
>Graphite Front Shock Tower - HPI: 73096 >Aluminium Rear Arm Mount Silver - New Era: HTM346S
>Aluminium Turnbuckles Silver - New Era: HMT339
>Rear Hinge Brace - HPI: 72229
!Twin-Plate Chassie!
---DRIVE TRAIN----------------------------------------------------------------------------
Torque Tubes: >Front CVDs (shiney) - HPI: 80814
>Rear CVDs (black) - HPI: 80874
Drive Cups: >2x Dif. Shaft (hard) - HPI: 86312
>2x Cup Joint D (hard) - HPI: 86315
Gears: 2x Final Gears Set (hard) - HPI: 86336
Dif. Gears - HPI: 86014
Bearings: >HPI Nitro MT2 Bearings Kit - JESpares:
---MOTORIZATION----------------------------------------------------------------------------
Engine: >.18 CV-RX Engine w/rotory carb - O.S:
Pipe: >Carbon Fibre Side Exhaust - Vantage:
Manifold: >Ported, High Volume Manifold - New Era: HMT421v2
Clutch: >Racing Cluth - HPI
Flywheel: - stock
Pinion: >13t Hardend Steel Pinion - Ebay.
Air Filter: >Motor Saver "Savage" Air Filter
Fule Tank: >100c Tank - HPI: 87189
Fule Line: >Fule Line Blue - Fastrax:
Fule Filter: >Big Daddy Fuel Filter - Dynamite:
!cold air intake!
---TUNE------------------------------------------------------------------------------------
>Dif. Tension springs - HPI: 72215
>Front Shock Springs (hard) - HPI: 6798
>Rear Shock Springs (hard) - HPI: 6593
>Wheel Nut Black - Trickbits: TB4515
>Shock Oil 30wt - GS: GS-700109
>Servo Saver Blue - trickbits: TB3015BL
>Angled Wheelie Bar - New Era: HMT343
>Claw Dawg Tires - Imex: 7575
M2 Gladiator Tires - Pro-Line: LXDX67
!Duel Brakes!
---Electronics---------------------------------------------------------------------------
RX: >3ch 27mhz Reciver - Futaba: R133
>Antenna with Aluminum Mount - RC4WD: ACC620BK
Steering Servo:>Digital, High Torque, Titanium Gears - Hitec: HS5997TG
Throttle/Brake Servo >High Speed, Steel Gears - Hitec: HS625MG
Failsafe: - Futaba
Battery: 6v highcapacity custom pack
Switch:
Misc. >Housing
>Wire
>Cable Brading
!lights!
!water proofing!
---LIGHTS----------------------------------------------------------------------------------
Head Lights: >5 x 5mm 22,000mcd 15° White LED (Headlights) - Dot Lite.
>2 x 5mm 22,000mcd 20° White LED (Headlights) - Dot Lite.
>5 x 5mm Internal Chrome Reflector LED holders - Dot Lite.
>2 x 5mm Internal Black Reflector LED holders - Dot Lite.
>7 x 6v-3.6v Resistors - Ultra Leds.
Tail/Brake Lights: >4 x 5mm 1650mcd 100° Red LED (Rear/Brake Lights) - Dot Lite.
>2 x 5mm External Chrome Reflector LED holders - Dot Lite.
>2 x 5mm External Black Reflector LED holders - Dot Lite
>4 x 6v-2.3v Resistors - Maplin.
