RCU Forums - View Single Post - Opto-isolator or not
Old 03-22-2006 | 08:11 PM
Erik R's Avatar
Erik R
My Feedback: (32)
Default RE: Opto-isolator or not
Martin,
It is possible that if you operate many of those servos under load at once,the voltage across your receiver will drop to the point that it causes an ECU commanded shutdown.So far I have only heard of the issue when deploying flaps,but obviously it could happen otherwise.It is only my opinion,but my only turbine aircraft loss was a direct result of this problem.Good luck,
Erik
