RCU Forums - View Single Post - RCS 180: please help
Old 03-22-2006 | 11:38 PM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RCS 180: please help
Hi
I tested run the RCS 180 with a fully charged 2100 Mah Nimh battery today. Same result: the engine is very difficult to start. Some time, smoke will come out of the back of the carb. If I am lucky and have it started, it will run with unstable RPM, and eventually quit after let idle for 10-20 seconds.
The engine is bought new, has never been inolved in a crash and has this problem after first gallon of fuel went through. It has been sent back to RCShocase twice. Before that, RCShowcas has nicely sent me 2 carbs and 1 ignition module to test. The problem persists.
Any suggestion is greatly appreciated.
Mike at RCS, can you please do something about the engine? I really do not want to waste any time on it!
--qc
test run conditions:
airframe: Gas Pattern (RCM plan)
mount: inverted
fuel: 32:1
prop: Menz 18X8
ignition batteries tested: 2100mah NIMH and Sanyo 1100mah nicad
muffler: KS muffler for 30cc engine
needle settings: RCS default (Low 1.0 out, high 1.5 out)
