RCU Forums - View Single Post - Mt2 gear changes..
Old 03-23-2006 | 06:20 AM
warnos16v
Default Mt2 gear changes..
Just a quick one...
My Mt2 has not been changing gears properly..
I have heard it change gears a couple of time when I first got it.. but since then.. no more...
I have tried winding the gear pin out 4 1/2 times with the standard screw but it still does not seem to change...
I really like the state of tune I have so I do not want to lean it out just to get the car to change gear..
How many times to you guys wind the gear screw out from being all the way in...
In the manual it states 4 times should be fine but not to go over 6...
Do any of you go all the way to six to get you car to change...
Warnos
PS when the car used to change gear it would bog down... in the 2nd gear... is the gear to lean?? I don't think it is...
as if I go any leaner after a long amount of driving the car will cut out up high.. which I believe is because it too lean.. so I have ritchened it up 1/8 and it fine.. but will not change gear.
