RE: U-Can-Do 3d 46?
Hey Gary.. Did you use your bearing pusher to get your prop hub off also?? Or
did you have a puller?? Did you oven bake the engine before removing the crank?
Or just use that good'ol tool..
I ordered some ceramic's with seals should be here shortly.. Are you going to go
seal / shield- less on the rear bearing?? Still need to order a gasket and seal set..
Many said to just use what I have... How about you??
Hey B Good.... Great weather coming.... That is until the Monster Heat arrives...
