RCU Forums - View Single Post - Has Monokote changed??
Old 03-23-2006 | 03:51 PM
  #37
Bax
Default RE: Has Monokote changed??
Usually, the only time we get such lines in the adhesive layer is if the material had to be stuck and re-lifted, or we've had to pull apart an area that we accidentally got stuck to itself. Of course when you separate such areas, you also usually wind up with some of the pigment removed.
