RE: Power switch for battery
Arming switches were common with brushed power systems. But you cannot use an arming switch with a brushless motor. When the switch is closed it will fry itself totally due to the large capacitors within the ESC. See the explanation in Bop Kopski's column in the August, 2004 issue of Model Aviation.
