RCU Forums - View Single Post - fabricating a cowl
Old 03-25-2006 | 11:46 AM
krazycdn
Default RE: fabricating a cowl
yes it works but you might need a 3 liter water bottle all yo du is make a plug out of wood or glassed foam insert it into a cut bottle ensuring the prop hole and bottle hole line up and us a heat gun to shrink the bottle down tight do not use balsa since when the bottle is shrinking it can produce upto 75psi
