RCU Forums - View Single Post - Took the bait
Old 03-26-2006 | 12:15 AM
agexpert
Default RE: Took the bait
You may get the needed throws by simply working the hinges a bit harder. CA hinges will usually loosen a little. Don't worry about breaking them, (unless you are trying to, you won't). Better to find a weak hinge now than on your maiden, anyway. Sometimes, if the surfaces are too close, simply um....amending the balsa, by working the hinges will do.
Good luck and...
Welcome to the end of 'free-time' and 'disposable-income' as you now know them.
