Suggestions for Controller setup
I just received AFPD friday.After realizing that some servo functions needed to be reversed,I opened the controller to find that the spring tension can be adjusted-Cool !! So Far I am having a blast.I am not sure how to best use the toggle switches.I have the 3 position switch setup like this- 1-gear down.2-gear retracted.3-smoke on.Can the 2 position switch be setup for low and high rate? What have you all come up with.
