Pattern help - consistent altitude
What helps me is to count to myself when I'm trying to fly symetrical manuvers. For example, when you do a stall turn as soon as you pull up count 1 one thousand, 2 one thousand...etc. until you reach the desired height make the turn, then count the same number going down and pull out. On down lines you may have to count a little less, but you get the idea.
Greg
