RCU Forums - View Single Post - The new Lanier Edge 87"
Old 03-26-2006 | 10:38 AM
  #224
yarom's Avatar
yarom
My Feedback: (82)
Default RE: The new Lanier Edge 87"
Josh, what did you do for the choke?
On the DA 50 there is a very little lever that requires quite a hard pull to open and close.
I put a servo on it temporarily, but I doubt it is that necessary. The same servo doubles for me as ignition cutoff (one side of the arm moves the choke, the other one hits the switch).
Is there a way to connect a lever to it and pull it only when needing to prime the engine?
