RCU Forums - View Single Post - Header for Brison 3.2
Old 03-26-2006 | 06:52 PM
T28Driver
Default RE: Header for Brison 3.2
Hi Guys,
Well, the parts came in from both Desert Aircraft, and Aircraft International so I'll post some picks of what was sent.
In my previous post I talked about how Desert Aircraft only had the header flange in stock (not the header). Not knowing that Aircraft International also carried the KS line, I ordered the header flange (and the rest of the exhaust system) from Desert, then after finding out about AI, ordered the completed header (and some other goodies ) from them.
The first two pictures show how well the header flange mates to the exhaust port. The second two pictures show the actual header bolted in place - one note here: the tolerances on the flange are so close that there was a little bit of binding trying to thread the bolts in. I opened up the two mounting holes with a bit 1/64 larger than the stock holes - then everything bolted into place smoothly with no binding. The last shot shows all of the muffler system parts that I ordered - it turns out that on my plane just using the elbows will work to bring the muffler out perfectly centered between the mains.
Just a note... both companies shipped quickly. Aircraft International's customer support was excellent as they tried twice to contact me 15 minutes before shipping closed, to correct an address mistake, so I would have my parts in time - Thanks guys!
Hope this helps the subscribers to this thread!
...Rob
ID:	433596   Click image for larger version
ID:	433597   Click image for larger version
ID:	433598   Click image for larger version
ID:	433599   Click image for larger version
ID:	433600   Click image for larger version
