Hi Mark,
Ditto to all that has been said. A tail dragger has got to be easier to taxi than a trike with a loose steering arm
. File a flat on the nose gear wire and it won't slip. There won't be much of a take off roll with your you-can-do.
When you have a bit of time move the CoG to the rear a few mm at a time on the stik trying with each change
Cheers,
Colin
