RCU Forums - View Single Post - wing loading definition
Old 03-27-2006 | 08:59 AM
mesae's Avatar
mesae
Default RE: wing loading definition
ORIGINAL: fledermaus
When we think of the wing loading as simply a descriptive parameter then it is hard to see why it would change. We should note however that the wing always generates lift normal to its chordwise datum line. A little geometry shows what could be regarded as an increase in effective wing loading.
As the AOA increases the wing's lift vector tilts forward away from "up and down" but only the component of this vector along the "up and down" line actually contributes to "lift" defined as the force holding the weight of the plane up in the air. This component is smaller the greater the AOA. That is, less of the work done by the wing is holding the plane up, so we can regard this in a sense as increasing the loading of the wing - the plane has to fly faster to generate the lift needed to remain at a constant altitude.
[img][/img]
Another way of thinking of this is that the cross-sectional area of the wing as viewed along the "up and down" axis decreases as the AOA moves away from 0 degrees. Since the mass of the plane is constant (neglecting fuel consumption etc) the wing loading at that moment is effectively greater because the wing is generating "lift" as if it had a smaller chord.
If we are going to talk vectors and take the time to draw diagrams, the I must speak up here. Lift acts perpendicular to the free-stream velocity, or flightpath, NOT the chord line. The above text and diagram is therefore highly misleading. The force perpendicular to the chord line is called the normal force, and is a resultant vector of the lift and induced drag vectors. The reference to an increase in effective wing loading appears to be a result of the misidentification of vectors. Not considering tail lift, a wing generating 1 g of lift at 1 degree AOA is still generating 1 g of lift at 10 degrees AOA at a lower speed. The "effective wing loading" hasn't changed at all. The lift vector is operating perpendicular to the flightpath in both cases (straight up if flying straight and level). The normal force vector is one that varies with AOA. Again, this discussion neglects tail lift that could increase or decrease wing loading.
