RCU Forums - View Single Post - balance
Thread: balance
Old 03-27-2006 | 01:54 PM
striderjg
Default RE: balance
Thanks darock. That sound like sound advice to tailer the balance with flight. I have to run out to lhs today to pick up a charger/switch jack, I may pick up some stick on weights as well to take with me to the feild. Just about evertyhign is done. Woot. Just need the charger/switch jack, then tweak the Aliron throws. I must have gotteen the wholes on the servo wheel wrong. To much differantial. 10+ mm down and only about 5 or maybe less up. So I need to play with that too. I'll try some of the stock holes and see if I can make it work with that, or just increase the throws and use epa to tune it down.
-John
edit --
Oops, wasn't thinking. One side goes up and one side goes down either way. Epa won't do **** for that. Lol. So looking at the hole placement on the servo wheel I guess.
-John
