RE: McCulloch 31cc w/ Rear Exaust and Carb, is it better?
Thanks, I found it on Amazon. Sounds like a good book. Finally here are the pix I said I would post. This first post will be after I took all the weedwacker stuff off and then the next post will be after I temporarily put everything together to make sure it ran. If you want to see the first set of pix, check out the 1st page of this post.
