RE: just a question
your running too lean, not enough fuel, richen it up, its starving for fuel at top end so it boggs down. if it was too rich it would be running cooler. if its bogging down on take off then the low end needle may be a little rich, you may need to lean it a little but if your running it wide open and it stalls or boggs then you need to richen up the high end.
