RE: Beginner builder looking for advice.
The Fantasy was my second plane and it is a handful coming from a high wing trainer. They have designed out the elevator flutter problem, so it should be a good kit. First, it is fast. Second, you really have to learn how to land it. I've seen experienced guys making 5 or 6 approaches before they could slow it down enough. There is a trick to it, of course. You just stay high on final and pull the nose almost level. It will settle into a nice angle on its own. Don't touch the sticks until you are ready to give it a hint of a flare around 4-5 inches off the ground. The wing is a real floater that low. Don't pull back on the elevator after landing as it will take off again when you swear it is finished flying.
The SSE is an easy build and it makes a great second plane with the throws kept down. Everybody should have one sitting around.
