For a 2-cycle engine there are several ways to make it work. The easiest is to use the reverse pitch prop. For an engine with a fixed front housing a reverse rotation crankshaft would be the next choice.
For a removable front housing engine(Enya), as Jen says, rotate the front 90 degrees left (from the front). If the engine has a rear intake, that would be 90 degrees right. Just make sure the intake opens as the piston is going up.
Swapping the front and back (per OS-FSR) would merely reverse the exhaust. For that engine just rotate the intake 90 degrees.
Using a reverse pitch prop is not the best choice since all model engines (
AFAIK) have the thrust bearing surface between the front surface of the crank web and the crankcase (or crankshaft housing). Using a reverse pitch prop puts the load on the BB's or the thrust washer to crankcase surface (often separated by a washer).
George
