RE: First Kit Build - Sig Somethin Extra
I strongly recommend upgrading to aftermarket pushrods for the tailfeathers. My experience has been that they don't slide that smoothly. Also on a hot day you will need to make trim changes because they expand (lengthen) as temp increases. I used the stock outer tubes with 2-56 metal rods sliding inside (threaded at the tailfeathers for adjustment).
