Prep for covering
I use a 50/50 mix of regular Elmers white glue and water. Wipe on the sheeting with foam brush and go right behind it with paper towel to avoid heavy soaking of wood. Let dry overnight and sand with 400 to 600 grit sand paper, tack cloth and cover. This alows the wood to be sanded nice and smooth and helps covering bond with wood.
