RCU Forums - View Single Post - Covering Tension
Old 03-28-2006 | 04:29 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Covering Tension
MasterAlex,
Yes, joining the two prior to putting it on the plane is more difficult. This is because it's hard to keep the line between the two colors in the place where you want it. It's also possible to have the line "warp" as you heat it. If you're just starting to use monokote it might be easier to just lay down the second color using windex.
Ken
