RE: Comp-Arf Lightning
Gary I sent you a E mail so I can send you pictures. After looking at your platform I think I made mine longer. Up front I have a 3300 nmh that Jet Cat supply long ways almost touching the nose. Behind it are 2 1900 Dualities and then my 3 jet tronic valves, 2 retract 1 brake. plus sequencer. Then 2 air tanks. The platform that go's against the retract bulkhead I have smoke pump, propane,fuel valves and fuel pump. Mine came in about 1/8 nose heavy.
Dave did you add a off set hinge in the middle between the stock set up ??
Thanks Dan
