RCU Forums - View Single Post - First Kit Build - Sig Somethin Extra
Thread
03-28-2006 | 08:54 PM
66
tuwood
Nov 2005
841
Omaha, NE
RE: First Kit Build - Sig Somethin Extra
I put the OS 46 in mine & had the same issue. here's what I did. I cut a hole in the side of the fuse so I could turn the needle sideways because it got the screws out of the way & let it slide back to where it was about 1/8" off of the motor mount back.
It still makes the motor stick out a little more than the plans but it doesn't seem to bother mine & you'll also find that you need to add some nose weight if you use the 2-56 wires & the tail feather support wires. ( I had to add 3 oz. in the nose). I also had to shove my battery pack all the way under the fuel tank against the firewall so make sure you have enough room under there.
I took a couple pictures for you.
BTW, everythings looking good so far!!
Reply
Like
tuwood
View Public Profile
Send a private message to tuwood
Visit tuwood's homepage!
Find More Posts by tuwood
View iTrader Profile
