Guys, thanks for the advice!!!! Definitely put it to good use. I ended up turning my needle vertical, and then moved the engine 1/4" forward as suggested and that works out.
I am glad to hear that you still need to add front weight, I was concerned about being front heavy having to move the motor forward.
You guys are life savers ... I will reward you with PICTURES later on!
