RCU Forums - View Single Post - Tornado XP Engine Sieze
Old 03-28-2006 | 10:54 PM
Popper252's Avatar
Popper252
Default RE: Tornado XP Engine Sieze
Those little plastics clips you're refering to are for the suspension, you slip them above the spring to make the ride harder. The thicker ones stiffen things up more than the thinner set. I guess you can use the clips rather than using the screw on the actual shock itself. It took me a while to figure out what they were too
