RE: Covering Tension
Thanks for taking the time for your good post Ken, very informative. The one step I didn't use was shrinking with the heat gun after sealing the edge. I went with using the iron to get the wrinkles out. I can see where the gun would have been an excellent tool for that. Had one sitting on the shelf and never thought of it. I also missed putting pin holes between the rib bays, hope it doesn't cause to much trouble. As this is my first trainer I'll probably have some work to do to it. I am semi satisfied with the turn out, one of those jobs that looks good from afar, but far from good. I did pick up some techniques from this first go at it and from the help from the group I look forward to the second plane.
flynte
