Dumb question
As the plane gains speed the engine will unload and turn a higher RPM. I think Chuck is right, you need to shorten the pipe from the peak on the ground or the engine will be past the ideal RPM that the pipe is tuned to. This works great for straight and level speed. But then again if you want more power on uplines the maximum on the ground setting just might work. It certainly would be the best setting for hovering a plane.
