RE: Goldberg Ultimate 10-300 build
I have not seen any discussion on motor mounts. As a rule, I usually use some type of vibration mounts on 4C's over 120. Most mounts I feel have too much movement and make setting thrust alignment impossible when the mount can move +/- 5 degrees. Not to mention the fact openings in cowls need to be larger to accomidate the movement.
I am using a Sullivan Dynamount, it is tighter then most allowing me to dial in within 1 degree accurately. Unfortunately Sullivan has always had problems keeping up with production. Mine was on BO for 3 months.
What are others using?
Thanks.
