BOBCAT servo's question?
My Bobcat has around 250 flights on it with the following
8411's on ailerons
3301's on elevators
9411's on rudders
460t gyro (Started with a 450 it died, then 2 460's third one was/is a charm) Run the gyro at 10% with gear up and about 60% gear down and you will have a solid airplane. I leave the knob active on the gyro gain so that I can crank it up a little in windy conditions.
BTW the P-120 on it is still running strong with ZERO problems.
