RCU Forums - View Single Post - Tornado XP Engine Sieze
Old 03-29-2006 | 05:35 PM
AJsToyz's Avatar
AJsToyz
Default RE: Tornado XP Engine Sieze
Bill,
Tried the radio switches , tried to trim the radio , nothing. I think the actual stall might have been the idle screw backed out to far, but the radio is acting funny. It only does it to the throttle. If you reverse the steering , it reverses. Trim the steering , it trims. No matter what you did to the throttle trigger it would not release the servo until you shut the transmitter off. After that the servo would go back to the middle. Turn the transmitter on , it would actually twist the servo arm and start torking the linkage. Turned it off again then back on it di a little throttle/brake dance for me then jambed the brakes on again. I wouldn't if I was pulling or pushing the trigger but I wasen't . I'm just glad the brakes came on and it didn't go the other direction , that could have been harsh!!
Andy
