RCU Forums - View Single Post - SOME BASIC QUESTIONS
Old 03-29-2006 | 07:21 PM
ob nut's Avatar
ob nut
Default RE: SOME BASIC QUESTIONS
Before heading out for the first day, do one simple item that will stop any headaches down the line. If the head bolts are open to the water in the water jacket, take all the head bolts out. Put a dap of anti-seize on the area of the exposed threads. Make sure the bottom of the screw has some blue loctite there. The reason for the anti-seize is that the salt won't be able to corode the metal screws. If this step is not done, it will be a pain in the rear to get them out. The loctite will make sure the screw does not back out on it's own.
I'd suggest flush everything, not just the motor, with water. Might want to spray a light mist of WD-40 where there is metal also.
