RCU Forums - View Single Post - 120 gemini help
Old 03-29-2006 | 07:30 PM
AllTheGoodNamesAreTaken's Avatar
My Feedback: (180)
Default RE: 120 gemini help
Which plugs are you using? Try some fresh four stroke plugs. Is the valve lash on both cylinders in spec? While it's running at idle, spray some WD-40 using the little red hose around the carb and intake manifold. If the idle changes, you have an intake leak.
