JETI speed controller
Which Jeti, what battery, what motor ? Is the battery fully charged ? Have you connected it to the receiver ? In the throttle channel ? Does a servo work when connected to the same channel ? Is the throttle at zero when you switch on ? What radio are you using ? Futaba radios usually need to have the throttle reversed.
It often helps if you provide a little more information.
Steve
