Dan,
colder outside temps=denser air=richer mixture is a general rule, especially for the high end. Try starting with the low needle 1 full turn CCW. Set the high end as normal, a few hundred rpm shy of peak rpm. This should get you in the "ballpark" barring other problems.
"Almost cold to the touch" is a mystery.
