RCU Forums - View Single Post - Water Rudder Problem
Old 03-30-2006 | 01:35 AM
jamesg33
Default RE: Water Rudder Problem
I think the problem is at the nose gear linkage. You need to adjust the control arm so that it is 90 degrees to the pushrod when the servo is neutral. That way you get the same amount of pushrod movement in either direction, and it will have the same mechanical advantage when centering from either direction.
Jim
