RE: Help with gyro settings
When you move the linkage in on the servo don't forget to adjust the limit on the gyro, the closer the gyro is to 100 the better it will perform and the servo will get less stress. I'm speaking of 0 to 100 on my Futaba 9c so if you are using a gyro menu, then they would be the same.
