RCU Forums - View Single Post - Getting 1/2 stick to equal 1/2 throttle...
Old 03-30-2006 | 02:04 PM
xray328
Default Getting 1/2 stick to equal 1/2 throttle...
My Enya .15 wasn't shutting off. So I removed and disassembled the carb, easy enough. But now I can't get the stick setting to equal the throttle setting. I have tried to adjust the arm on the barrel (loosened the screw and moved the arm) The servo is trying to push the barrel arm too far at both open and closed throttle. I can adjust that with EPA's. But when I do, from 0-50% stick movement only gives me 0-25% barrel movement. Then 51-100% stick movement =26-100% barrel movement. So 1/2 stick movement is 1/4 barrel movement. The barrel moves slowly below 1/2 throttle and quickly from 1/2 to WOT. How do I fix this? I have a Futaba 6EXA.
Thanks!
