RCU Forums - View Single Post - Bulletproofing FunFactor
Old 03-30-2006 | 02:34 PM
  #42
BootMachine
Default RE: Bulletproofing FunFactor
Not including proto's and machine set up......1/2 a day's labour to do each section.
2 sections per part so......100 bucks for front and 100 for rear...if 10 people buy them...150 USD for both.
Thats $1500 in your pocket Dr.Honda....so....with all the set up and building your milling strategy (if you can get it done in 2 days) you can profit 1/2 of that!
The only parts that need a good finish are where the bearings sit and the hinge pins go through...
I have the ARO shock towers so I'm going to size my holes for mounting to those...
The bottom holes and locating pins will be sized according to the stock FF chassis. I dont have the JT racing chassis.....YET!
I want to take my time with some of the measurements so Dr. Honda wont have to make too many proto's.
To cut down on machining time I can remove a bunch of chamfers and fillits I added just to make things look good.
I will only chamfer the pieces that need it.
Dr. Honda...Hook me up and I can draw the front for you also.
Feel free to use my drawings to make as many as you like and set your own price. Feel free to put your "ARO" mark aswell!
