RCU Forums - View Single Post - JR Matchbox Setup, Tips, Tricks
Old 03-30-2006 | 04:41 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: JR Matchbox Setup, Tips, Tricks
Whatever. Do it your way. I'm just posting what I know works.
I'm not saying your wrong. I'm just saying, that if you make sure everything is equal. All servos and linkages are the same distances--you won't have problems.
Maybe you know some way to do it where the CL of the output shaft on the servo doesn't have to be the same distance on each servo. Maybe it works.
I KNOW that if you put the CL of the output shafts equal distance and make all the linkages and horns the same--it will work right. I DON'T know if placing the servos at different distances from the hingeline will work or not. I quit trying stuff like that years ago when I discovered that your better off to just make everything the same distance.
