RE: Water Rudder Problem
Thanks guys, I will try and use your suggestions to help make it work better. I don't know if you can see from the picture, but the pushrod is supported behind the front mouting strut also. I'm not sure if I will try to give it more support, or if I will do what N7OR said and not sweat it. From looking at the pictures are there any other problems you can see? If not, great!
LT-40
